Neues ScenalyzerLive vom 15.11. !
Beitrag Beitrag 0 - Verfasst am: Di Nov 19, 2002 19:26    Titel: Antworten mit Zitat
Wer es vielleicht noch nicht bemerkt hat:
ScLive history:
20021115 added: File/Writer-Speed-Test to test the speed of .avi file writing
added: File/Print
added: new options for the clipssheet under File/Options/Clipsheet
added: Sclives Audio Resync-module can be switched off
added: when the Monitor-Window is undocked, you can use left/right/up/down to scroll scrubb the video
added: playback-controls
added: a peak meter :-)
added: capturing the second audio channel to a .wav file at the same time when capturing an .avi
added: the number of pixels to be cropped can now be set in sclive
added: options dialogs for the StudioDV Deluxe, the DV500 and the Canopus DV-Storm
added: pushing "Enter" in the Cliplist immediately plays the files
added: support for 16:9 capturing with the Canopus Cards and the Pinnacle cards - the files now show the correct aspect-ration in premiere
added: if sorting is done before the clips have been scanned, sclive shows a progress-dialog
added: Support for the EZDV and RaptorRT, Playback to Canopus-Cards, the EZDV, RaptorRT and Storm need the newest drivers in order to run with sclive
fixed: buffer underruns in sclive when playing back avi files
fixed: perfect A/V sync for analog capturing-devices
fixed: problems with the Canopus ADVC-100 (please check the option "disable device control" for Analog-DV converters connected to the 1394 bus)
fixed: audible clicks under certain conditions
fixed: sclive didn't write the extension when the pathname contained the ' char.
fixed: sclive now uses "h.mm.ss.ff" (instead "mm.ss.ff") - timecode for pathnames
fixed: sclive now uses 1/2 second audio-interleave for the Type2 file format now - fixes sync probs with the DV500
fixed: A problem with NTSC video in vegas: sclive now writes NTSC files at a framerate of 30000/1001 fps instead of the 29970/1000 fps used previously.
20020509 added: analog capturing now supported from the DV Storm's analog inputs
20020505 added: Sclive supports capturing from the Canopus DV Storm's 1394 inputs.
You will need Storm drivers V.1.05 or newer!!!
Not supported: Analog Capturing, Playback and 16:9 picture format.
note: this version is based on the 20011115-release
added: 2nd audio channel can optionally be captured
20011102 added: sclive can now capture the 2nd audio channel
added: sclive does still not support canopus cards, but it can now capture canopus-compatible avi's from non-canopus cards
added: in the context-menu of the undocked Monitor-Window, the size of the window can now quickly be set to full, half or quarter
added: "Microsoft DV Camera/VCR" devices can now be assigned a meaningful name like "Sony VX2000 Camera" using the "..." next to the device-combobox
fixed: crash when selecting a non-dv capture device
fixed: sclive sometimes crashed when the 6th or 7th scene was captured.
20011011 fixed: sclive now runs okay under XP
http://www.scenalyzer.com/d/download.html
Die neuen Funktionen machen sich sehr gut
