Beitrag 0 - Verfasst am: Sa Nov 02, 2002 16:10 Titel: |
Changes:
Build 14279 (Version 1.4.11): [October 31, 2002]
[features added]
* Added support for reading and writing TARGA (.tga)
sequences, with optional RLE compression.
* Added simple logo filter.
* Added (not-quite-optimzed) HSV filter.
* The "Save Image Sequence" command is now batchable
and scriptable.
[bug fixes]
* Fixed OpenDML files having bad duration values in
their index if video frames weren't all the same
size.
* Fixed some subset-related position slider glitches.
* RLE AVI files weren't being decompressed correctly
(GDI's RLE isn't the same as AVI's RLE).
* Fixed crash disassembler not disassembling some
instructions properly.
* Fixed glitches in the first three frames of the
temporal smoother's output.
* Fix for some MPEG rounding errors (arrgh).
* AVI parser now accepts and reindexes LIST/movi chunks
with 0 sizes.
* AVI parser no longer drops stream 0 samples at the
start of a file when reindexing.
* AVI video reader detects and flips inverted RGB DIBs.
* Fixed 1/16th darkened line on left side of "blur more"
filter.
* Added support for properly cloned filter data
structures.
* Allowed position control font to enlarge slightly
according to screen dpi and fixed font leak.
* Fixed MIME BASE64 encoding errors at end of codec
configuration blocks that probably caused some codec
crashes or configuration funniness.
* Calls to video codecs now eat MMX errors rather than
reporting them, to workaround a bug in the MSMPEG4V3
codec that will probably never be fixed.
* WAV writer now writes out the required 'fact' chunk
for compressed WAVs.
* Filter preview dialog now sanely reports errors in a
http://www.virtualdub.org/index
Link:
hXXp://unc.dl.sourceforge.net/sourceforge/virtualdub/VirtualDub-1_4_11.zip _________________ Wenn mer sich uffreche will: - Eintrachtfan und SPD Mitglied! |
