aDVanced DV PAL/NTSC Converter Version 1.05
Beitrag Beitrag 0 - Verfasst am: Do Sep 12, 2002 13:52    Titel: Antworten mit Zitat
Quality DV Software Tools : aDVanced DV PAL/NTSC Converter Version 1.05. Features:
High quality NTSC<->PAL conversion with motion interpolation
Imports QuickTime®, QuickTime® Reference Movie, AVI Type 1 and 2 (with or without OpenDML extension), Reference AVI Type 1 and 2, Raw DV (.dv/.dif/.dvsd), SONY ES-3 DV files (.dv)
Exports QuickTime® (with or without separate audio track), AVI Type 1 and 2 (with or without OpenDML extension), Reference AVI Type 1 and 2, Raw DV (.dv/.dif/.dvsd), SONY ES-3 DV files (.dv)
Any DirectX or Video For Windows codec can be used
Correctly handles interlaced and progressive scan with optional deinterlacing
NTSC to PAL options: Scale Up/Letter Box/Pan And Scan/Letter Box Plus Pan And Scan
PAL to NTSC options: Scale Down/Crop
Time resampling modes: motion interpolation, frame duplication/drop, frame blending
Batch conversion
Data conversion: DV/DVCAM to DVCPRO25 or DVCPRO25 to DV/DVCAM
Command line version; useful for scripting
No filesize limitation: proper handling of >4GB (AVI, QuickTime, Raw DV...) files
aDVanced DV PAL/NTSC Converter is fully functional shareware. The unregistered version can be used for evaluation purposes only. The only limitation in the unregistered version is that an "Unregistered Version" watermark is written inside the DV frames. Download (Windows2000/NT/XP, 1250 kB)
Download !
Info Webpage
