SVCD Fehler?!
rEaL TriPpeR
Anmeldungsdatum: 09.06.2002
Beitrag Beitrag 0 - Verfasst am: Mi Jun 19, 2002 21:00    Titel: Antworten mit Zitat
Hi, möchte gerne meine SVCD ankucken habe sie auf dem rechner... Nur lässt sie sich nicht ankucken, benutze WinDVD.
Dann wollte ich sie brennen bzw. ne .bin datei erstellen doch da kam dann nur ein Fehlerbericht:
[Internal Xml Generation]
Internally computed XML generated successfully as "C:\WIN98\Desktop\videocd.xml"
[VCDxBuild.exe]
GNU VCDImager 0.7.12
initializing libvcd 0.7.12 [cygwin/i686]
this is the UNSTABLE development branch!
use only if you know what you are doing
see http://www.hvrlab.org/~hvr/vcdimager/ for more information
changed volume number to 1
changed volume count to 1
changed restriction number to 0
changing 'next volume use sequence 2' to 0
changing 'next volume use lid 2' to 0
changed volume label to `SUPER_VIDEOCD'
changed publisher id to `VCDEASY_V111'
changing 'relaxed aps' to 0
adding pbc (Selection-000/2)
adding pbc (Selection-end/3)
sequence count 1
adding sequence #0, D:\AsianMania.SVCD.DVDrip.XXX-EM\Neuer Ordner\AsianMania.DVDrip.SVCD.CD1.XXX-EM.mpg
unexpected start code 0x00000113
unexpected start code 0x00000115
unexpected start code 0x00000116
unexpected start code 0x00000117
unexpected start code 0x00000118
unexpected start code 0x0000011b
unexpected start code 0x0000011c
unexpected start code 0x0000011d
unexpected start code 0x0000011e
unexpected start code 0x00000101
unexpected start code 0x00000103
unexpected start code 0x00000104
unexpected start code 0x00000105
unexpected start code 0x00000106
pos != buflen (2321 != 2324)
mpeg scan: pack header code (0x000001ba) expected, but 0x000003ba found (buflen = 2324)
bad packet at packet #15633 (stream byte offset 36331092) -- remaining 791824054 bytes of stream will be ignored
pts start offset 0.213367 (max pts = 145.425100)
playing time 145.211733
scanning mpeg sequence item #0 for scanpoints...
already scanned... not rescanning
pbc: psd size 56 (extended psd 0)
iso9660: highest alloced sector is 225 (using 300 as isosize)
OGT streams available: 0 0 0 0
writing track 1 (ISO9660)...
writing track 2, MPEG2, NTSC 2/3 D-1 (480x480/30fps), audio[0]: l2/44.1kHz/128kbps/stereo ...
file vcd_mpeg_stream.c: line 411 (vcd_mpeg_source_get_packet): assertion failed: (pkt_len > 0)
Hab nicht so wirklich den Durchblick woran das liegt.
Weiß jeman was das bedeutet und was man da tun kann?
Auch ICQ: 161962572
cu
Beitrag Beitrag 1 - Verfasst am: Mi Jun 19, 2002 21:04    Titel: Antworten mit Zitat
Lass die Fehlermeldungen durch Altavista Babelfish "Fachchinesisch --> Bayrisch"
derubier
Vidac-Spezialist
Anmeldungsdatum: 27.02.2002
Beitrag Beitrag 2 - Verfasst am: Do Jun 20, 2002 1:53    Titel: Antworten mit Zitat
Sieht vielleicht nach einem Headerproblem aus. Wenn nichts läuft, dann Film wegwerfen oder neu erstellen.
GRuß
Der Ubier
Beitrag Beitrag 3 - Verfasst am: Do Jun 20, 2002 9:30    Titel: Antworten mit Zitat
@rEaL TriPpeR
Wenn schon mit WinDVD nicht geht, dann brauchste auch nicht brennen.
adding sequence #0, D:\AsianMania.SVCD.DVDrip.XXX-EM\Neuer Ordner\AsianMania.DVDrip.SVCD.CD1.XXX- EM.mpg
Deine SVCD ist gerippt und wahrscheinlich mit falsche Muxrate, bzw. Encoder- bzw. Muxereinstellung.
Das dürfte die Ursache sein!
Ich weiß nicht, ob ein Demuxen und Neumuxen, z.B. mit bbmpeg da weiterhilft.
Aber da stellt sich eine andere Frage, ob wir wegen den Nutzungsbedingungen dieses Forum, überhaupt noch weiter darüber unterhalten können...??
grettsche
Master of Disaster
Anmeldungsdatum: 15.03.2002
Beitrag Beitrag 4 - Verfasst am: Do Jun 20, 2002 9:57    Titel: Antworten mit Zitat
hmmm, ich glaub da musst Du nach Amerika fliegen, Dir dort nen Computer kaufen, einen amerikanischen Softplayer installieren und dann könntes auch mit dem Fidscho klappen. ;)
Gruss grettsche
Beitrag Beitrag 5 - Verfasst am: Do Jun 20, 2002 10:04    Titel: Antworten mit Zitat
@grettsche
Interessant, das habe ich irgendwie nicht gesehen. Das erklärt aber doch nicht, daß (a) nicht mit WinDVD angeguckt werden kann und (b) die packet size wohl eine Idee zu klein ist, oder?
grettsche
Master of Disaster
Beitrag Beitrag 6 - Verfasst am: Do Jun 20, 2002 10:07    Titel: Antworten mit Zitat
Guten Morgen SVCDFan ! ! !
Gruss grettsche
Beitrag Beitrag 7 - Verfasst am: Do Jun 20, 2002 11:34    Titel: Antworten mit Zitat
Vermutlich wieder son vermurkstes Ding aus dem Internett.
Wenn man keine Ahnung hat soll man seinen Scheiß , nicht ins Netz stellen. Und wir reißen uns für so nen Müll regelmäßig ein Bein aus. [WutSchnaub]
Gleiches Thema :
Rippen,Screenen,Cam-en, DIVx'en
Was ist verboten, was ist erlaubt?Eine fundierte Diskussion
http://www.dvdboard.de/forum/showthread.php?threadid=29519
rEaL TriPpeR
Beitrag Beitrag 8 - Verfasst am: Do Jun 20, 2002 13:20    Titel: Antworten mit Zitat
Danke dann werd ich sie wohl löschen. Ja hab sie aus dem netz. naja was solls.
cu
