shh
Beitrag 1 - Verfasst am: So Okt 06, 2002 16:00 Titel: |
Was hat sich mit der Version geändert?
bugs fixed:
bugs introduced:
p.s.
ok, hab was gefunden:
Changes From Nero 5.5.9.9 to 5.5.9.14:
Bug Fixes:
- Full-O-Meter shows the correct size for DVD-R/RW and DVD-RAM
- Only Disc-at-once is visible in the recorder settings for DAO/96-only-recorders
- Files cannot be dropped to the main window any more while a modal dialog box is open
- Resized edit fields on New compilation -> date-tab
- Disable multisession for DVD-Video compilations
- Fixed a problem in the save track dialog, which occurred hile trying to jump to an index positions within an audio track
- New message if you drop an invalid file in a VCD or SVCD compilation
- Added the possibility to continue burning even when the compliance test of DVD-Video files fails
- Fixed issue with verify and DAO/96 on some drives
- NeroExpress: allow only one copy of Multi Session-Compilations
- Nero Express: Fixed rare Unexpected Errors at the beginning of the burn process with some drives
- Nero Express: WMA plug-in shows different messages for corrupted, wrong or copyright protected files
New:
- Added several new recorders
- If possible, Image-Compilations now allow to change the compilation type (DVD,CD, ...)
- Added multisession support for bootable discs (note: track linking is only possible with non-bootable multisession discs)
Das bugs introduced wird wohl erst wieder in Folgeversionen klar... _________________ shh >>> shh's MPEG-tools |
