InstantCD/DVD VOB
Beitrag Beitrag 0 - Verfasst am: Fr Apr 12, 2002 19:30    Titel: Antworten mit Zitat
Professional CD/DVD recording made easy. InstantCD/DVD
Webpage zum Updaten und für Infos
InstantCopy (version 6.4.0.15)
Copying from DVDs via harddisk symbol is working again
UDFLIB.DLL (version 1.0.1.20)
Better sorting of files on the CD/DVD. This results in a better read speed when copying back the datas. (up to 3.5 times faster)
ASAPI (from 15.01.2002 6.0.0.0)
Bug under NT4 removed. When the burner was running in the DMA mode, the computer was likely to crash as soon as InstantDisc or InstantCopy were started
InstantVideo (version 2.2.3.727)
Problem when burning PhotoCDs removed. The second track is now longer than 300 sectors. Some burners have problems, when the track is shorter.
InstantVideo now requires DirectX 8, this results in the fact that the program does not run under NT4.
InstantVideo can now create MPEG2 streams for SVCDs
In addition to AVI files, MPEG files can now be converted as well
InstantDisc (version 6.4.0.30)
When burning DVD films out of the Video_TS file, the IFO files are now analyzed. This results in a higher compatibility to various DVD authoring programs
InstantWrite 4.0.0.0
Error of closed Inc medias removed. The Windows UDF driver under W2K/XP was partially not able to read the CDs
Mt. Rainier support
QuickFormat at Pioneer A03 (formating of a RW medium takes less than an hour)
Swapping out of defective sectors at Random Access medias
Autoformat under XP/W2K/NT not only possible with empty medias but from now also with existing sessions that have already been closed
Write-protection can be activated at DVD-RW
DVD-RW RandomAccess medias can now be closed, leading to the fact that the discs can also be read in the DVD-ROM (in order to achieve this, the drive has to be able to read -RW and there must be a UDF 2.0 read-only driver)
Update installation
Update errors removed; When installing the update error 105 could appear
derubier
Vidac-Spezialist
Anmeldungsdatum: 27.02.2002
Beitrag Beitrag 1 - Verfasst am: Sa Apr 20, 2002 22:31    Titel: Antworten mit Zitat
... und Helmut ist dieses Programm wirklich sein Geld wert. Oder gibt es auf der GNU-BAsis ein ähnliches Produkt.
Der Ubier
Beitrag Beitrag 2 - Verfasst am: So Apr 21, 2002 13:47    Titel: Antworten mit Zitat
Auf jeden Fall funzt das in Verbindung mit dem Pioneer DVD Brenner A03 bestens. Für nix anderes nutze ich das. Zum Brennen von CD´s oder SVCD´s gibt es besseres Programme und würde ich das Progi nie nehmen.
derubier
Vidac-Spezialist
Beitrag Beitrag 3 - Verfasst am: So Apr 21, 2002 15:58    Titel: Antworten mit Zitat
... also Helmut, dies ist also ein reines Authoring-Tool mit Brennrouting für DVDs. Gibt es dort etwa noch andere und sogar für umsonst?
Der Ubier
Beitrag Beitrag 4 - Verfasst am: So Apr 21, 2002 16:07    Titel: Antworten mit Zitat
...... dies ist also ein reines Authoring-Tool mit Brennrouting für DVDs..
Neee. Das kein Authoring-Tool - nur ein Brennprogi. Aber DVD-R wird gut unterstützt (UDF / VIDEO-UDF und IMAGE)
Kostenlose Tools - für was meinste jetzt ? Was willste machen ?
NZ
Beitrag Beitrag 5 - Verfasst am: Mo Apr 22, 2002 20:34    Titel: Antworten mit Zitat
Das Programm enthält in der neuen Version übrigens auch einen MPEG-Encorder mit bescheidener Qualität. Dafür hats nichts gekostet. Ansonsten eigentlich nicht schlechter als z.B. Nero.
