Beitrag 0 - Verfasst am: Sa Nov 18, 2006 22:31 Titel: IrfanView 3.99 |
Gravierende Unterschiede, Neuigkeiten, Verbesserungen, Sensationen?
Aja ... da
http://www.irfanview.com
Version 3.99 ( - CURRENT VERSION - ) (Release date: 2006-11-16)
Option to Search files (File menu or Thumbnails, Hotkey: CTRL+F)
Support for PDF export (PlugIn) (Thanks to ComSquare AG)
New Thumnails option: Load file list from TXT
New zoom workwise: Centered zoom or based on old scroll position
Zooming and scrolling is now possible in slideshow mode
Many new effects added: Unsharp mask, Fish Eye etc. (Thanks to GENiEBEN)
New Flash Plugin for Flash 5 or later! (Thanks to Remio)
Option to transfer files by FTP (Thumbnails window, PlugIn)
Option to set the Start folder (Properties->Misc 2)
New image option: Auto adjust colors (Thanks to Andras Horvath, www.log69.com)
New effect: Chromatic Aberration (Thanks to Thomas Strauss)
Support for SIF format (Formats PlugIn)
Support for PVR format (DreamCast Texture, Formats PlugIn)
Support for AWD format (Artweaver Format, PlugIn)
Support for VTF format (Valve Texture Format, PlugIn)
WMF format check added, to avoid WMF vulnerability (Thanks to Jakub Debski)
New Thumbnails sort options: Sort by portrait/landscape
Fullscreen option: Use right mouse button for scrolling (Properties -> Misc 1)
Fullscreen option: Set display multiplier (for wide screen displays)
New placeholders for EXIF/IPTC: $E, $I => to load all EXIF/IPTC data
Command line change for /resample! (see i_options.txt for examples)
New command line options: /resize_long, /resize_short (see i_options.txt)
New command line option: /panorama=(direction,file1,...,fileN)
New command line options: /bright=value, /gamma=value
Command line switch for /info: /fullinfo (write EXIF, IPTC and Comment)
Updated CRW/CR2 PlugIn, please install newest Canon DLLs (see i_plugins.txt)
Option to show a warning on ESC thumbnails exit (Thumbnails options)
New options in dialog: Create custom selection
Support for MP4 format (Quicktime PlugIn)
At request of Luratech: JP2/JPM/LWF/LDF are not available in Batch mode
New Hotkey: SHIFT + P = Copy current filename to clipboard
Added YUV (4:2:0) format support to Formats PlugIn
Help file format changed to CHM (Compatible with Windows Vista)
Most PlugIns are changed/updated, please install the newest versions
http://www.irfanview.com/plugins.htm
Some minor bugs/features fixed/added (add-all button, ANI/CUR loading, batch text) _________________
ACS
Anmeldungsdatum: 04.06.2003 Beiträge: 261
Beitrag 1 - Verfasst am: So Nov 19, 2006 19:35 Titel: |
Danke Cool!!!
Schon herunter geladen.
Eine Frage. Vielleicht kannst du helfen.
Habe in den Einstellungen bei der Slideshow "Überblendeffekt" eingestellt.
Wenn ich dann aber die Slideshow ablaufen lasse, ruckelt der Überblendeffekt.
Kann man dagegen was machen?
Besten Dank schon mal im Voraus für deine Hilfe und Info. |
Beitrag 2 - Verfasst am: So Nov 19, 2006 23:24 Titel: |
Hmmm, habs ausprobiert, mit einem Haufen *piep*-Mädels,
aber auch mit eigenen 8 Megapixel- und 10 Megapixelbilder .... RUCKELT NIX ! _________________
ACS
Beitrag 3 - Verfasst am: Mo Nov 20, 2006 11:44 Titel: |
Idiot blöder Idiot ich.
Hab bei meinem Acer Laptop beim ePower Management auf "Office Betrieb" eingestellt. D.h., nur mittlere CPU Frequenz. Da kann das nicht richtig funktionieren. Habe jetzt auf volle Leistung umgestellt und alles wird einwandfrei abgespielt. Bin nun wirklich zufrieden. Kann meine hochauflösende Photos mit Musik mit diesem Programm vom Laptop über den DVI Ausgang auf den Beamer übertragen. Echt cool.
Danke cool für deinen Test und deine Rückmeldung.
Schenke dir dafür ein paar sexy Bilder.
Klick dadrauf: cool
Sorry, ich kann den Link nicht stehen lassen,
Admin |
Admin  globaler Moderator
Anmeldungsdatum: 07.06.2001 Beiträge: 1068
Beitrag 4 - Verfasst am: Mo Nov 20, 2006 12:52 Titel: |
Den Link von ACS habe ich entfernt. Sorry. Das geht zuweit! |
Beitrag 5 - Verfasst am: Do Nov 23, 2006 20:53 Titel: |
Toll!
Was war denn da? _________________ Das perlt jetzt aber richtig.
http://tinyurl.com/d4r54z |
Beitrag 6 - Verfasst am: Do Nov 23, 2006 23:30 Titel: |
conan hat folgendes geschrieben: | Was war denn da? |
KEIN Skifahren mit Jack Sparrow !
Wer zu spät kommt, den bestraft das Leben!
Wer zu früh kommt, den bestrafen die Frauen!
(Altes Indianersprichwort) _________________
