Mediachance bringt DVDLab Pro Version 2.0
Beitrag Beitrag 0 - Verfasst am: Do Jul 27, 2006 16:34    Titel: Mediachance bringt DVDLab Pro Version 2.0 Antworten mit Zitat
Hier die neuen Features in Version 2:
Multiple Angles/BOV
The 2.0 adds many high-end features such as multi-angle, Buttons over Video, Multi-PGC title and more.
Compile faster than ever
We reduced the amount of large hard-drive data shuffling during compillation and by using in-place compilling we eliminated the need for having large temporary space. In addition we added Smart compile options that will recompile only changes in menus and keep the pre-build vobs.
More Menu Effects
With the perspective transformation you can design a fresh, new non-planar menus and use powerful Package object that will simplify complex menus.
Cells and Delayed menu buttons
Each menu can now have up to 30 additional still/audio cells with audio that can span across the cell boundaries.
Audio-Only Track
The new version adds second channel and the ability to insert new still image on any audio mark.
Rich virtual Editing tools
You can now pause playback on any chapter or let the movie pause at the and and wait for user to press play button. This is a great way to create presentations or assited guides.
Connection
The Connection window is even more powerful in the new version with multiple selections, Subviews that can separate project into smaller blocks or with Visible VM commands.
Mehr dazu siehe http://www.mediachance.com/dvdlab/dvdlabpro.html
Ach ja.. Upgrade auf Version 2 kostet zwischen $ 50 - $ 150
Beitrag Beitrag 1 - Verfasst am: Do Jul 27, 2006 16:36    Titel: Antworten mit Zitat
Ich bin noch unschlüssig, ob ich den Upgrade machen soll...
Beitrag Beitrag 2 - Verfasst am: Do Jul 27, 2006 21:43    Titel: Antworten mit Zitat
Weichei .....
Beitrag Beitrag 3 - Verfasst am: Do Jul 27, 2006 22:03    Titel: Antworten mit Zitat
Der Direktlink zum Proggi:
http://www.mediachance.com/files/dvdlabpro2.exe
Beitrag Beitrag 4 - Verfasst am: Fr Jul 28, 2006 19:36    Titel: Antworten mit Zitat
Ich glaube es ned!
Der Oscar hat endlich das AUDIO in die Vorschau integriert! ... UFFF !
DeMe
Anmeldungsdatum: 13.12.2005
Beitrag Beitrag 5 - Verfasst am: Fr Jul 28, 2006 21:05    Titel: Antworten mit Zitat
Ich glaube es ned!
Wurd ja auch mal Zeit.
Ging das nicht mittlerweile auch über ein externes Tool? Komme gerade net auf den Namen. Naja jetzt isses eh überflüssig.
Meine Trading Page
Beitrag Beitrag 6 - Verfasst am: Fr Jul 28, 2006 21:29    Titel: Antworten mit Zitat
DeMe hat folgendes geschrieben:
Pro Extension war das Teil.
Beitrag Beitrag 7 - Verfasst am: Fr Jul 28, 2006 21:43    Titel: Antworten mit Zitat
Pro Extension ..
kann man aber weiterhin einbinden!
Beitrag Beitrag 8 - Verfasst am: Sa Jul 29, 2006 10:30    Titel: Antworten mit Zitat
Muß ich vorher andere Versionen installieren, um die PRO 2 zu testen ?
Beitrag Beitrag 9 - Verfasst am: Sa Jul 29, 2006 11:27    Titel: Antworten mit Zitat
Nöööö.
Beitrag Beitrag 10 - Verfasst am: Sa Jul 29, 2006 12:02    Titel: Antworten mit Zitat
tach nochmal !
Danke!
Die Webseite ist irgendwie etwas verwirrend in diesem Punkt.
Beitrag Beitrag 11 - Verfasst am: Sa Jul 29, 2006 15:53    Titel: Antworten mit Zitat
Du kannst sogar parallel zu der bisherigen Version installieren.
jemue
Anmeldungsdatum: 03.12.2002
Beitrag Beitrag 12 - Verfasst am: Mi Aug 02, 2006 7:36    Titel: Antworten mit Zitat
Also ich werde das Geld dafür ausgeben. Durch die Audioeinbindung wird das sicher sehr interessant.
DeMe
Beitrag Beitrag 13 - Verfasst am: Mi Aug 02, 2006 14:53    Titel: Antworten mit Zitat
jemue hat folgendes geschrieben:
Hab's gestern mal getestet. Funktioniert leider nur bei gemuxten Dateien (VOB, MPEG)... sehr schade, für meine Zwecke immer noch nicht das Wahre.
Meine Trading Page
jemue
Beitrag Beitrag 14 - Verfasst am: Do Aug 03, 2006 7:50    Titel: Antworten mit Zitat
Danke, gut zu wissen.
Werd mal an WE die Trial sicher vor dem Kauf testen.
Beitrag Beitrag 15 - Verfasst am: Do Aug 03, 2006 9:17    Titel: Antworten mit Zitat
d.h. die Vorschau mit elementary streams gehen nicht? Das wäre echt suboptimal
Beitrag Beitrag 16 - Verfasst am: Do Aug 03, 2006 9:29    Titel: Antworten mit Zitat
Naja - was soll´s? Halt schnell muxen. Ich habe aber in der Regel eh gemuxte Files.
Beitrag Beitrag 17 - Verfasst am: Do Okt 05, 2006 15:32    Titel: DVD-lab PRO v2.18 Antworten mit Zitat
DVD-lab PRO v2.18
September 29, 2006
History:
QUOTE
- Fix: Audio problem compillation in multiple menu cells (adding audio to second cell will halt compilation)
- Fix: Slideshow compilling problem
- Fix: Manual routing for cells was not updated
Download (Update Only - 2.1 to 2.18 exe and dll files):
CODE
http://www.mediachance.com/files/DVDlabPRO218.zip
und hier
DVDlab Pro 2.18 deutsch patch
http://rapidshare.de/files/35195252/DVDlabPro2.18-Deutsch-Patch.exe.html
Bei einer Kaufversion funzt der Patch sofort.
Wer eine ***** Version fährt muss beachten:
nach dem update auf 2.18 erst eindeutschen und dann erst gesund beten!
