Media Studio Pro 7 Update dt. Vers. 7.20.0006
videowahn
Beitrag Beitrag 0 - Verfasst am: Fr Nov 19, 2004 2:03    Titel: Media Studio Pro 7 Update dt. Vers. 7.20.0006 Antworten mit Zitat
Servicepack 2 für dt. MSP 7 hier:
ftp://ftp.ulead.com/pub/updates/msp7/msp7sp2_g.exe
MPEG-Encoder jetzt mit 2-pass.
Weitere Änderungen siehe unten.
EDIT: Ach ja, endlich wurden die verwirrenden Fieldorder einstellungen A/B in oberes/unteres Halbbild geändert.
Installation problemlos. Nach der Installation läßt sich bei den Projecteinstellungen kein AC3 mehr wählen
Im Erstellen-Menü ist die Einstellung aber noch möglich.
Zum Testen bin ich jetzt zu müde. Nächstes Wochenende.
grüsse videowahn
Enhancements:
Support Ulead VideoStudio 8 project files. SmartSound in VideoStudio 8 project will be converted to silence audio clips
Add new filters and effect: Pan & Zoom, Duotone and Album transition
Support Recording Date/Time and display the arrangement. Production Library now supports extracting timecode from videos and audio/images from camcorders or digital cameras. Some camcorders and digital cameras may not record the media with recording date/time when using some specific settings. In this situation, the Production Library will not be able to show Recording Date/Time
Support VST audio plug-in
Support Auto Deinterlace. When creating a project using progressive scan and Auto Deinterlace is selected, all video fields will be automatically deinterlaced when creating the video file
MPEG-2 2-Pass Encoding option was added. 2-Pass Encoding can be only be selected when you create a file; it is not an option for a project template
Bugs fixed:
Problem with Video Capture crashing when the video has more than 100 scenes was fixed
Changed Field Order A to Lower Field First and Field Order B to Upper Field First
Problem of the video flickering at the end of a transition effect was fixed
[For Ulead HD Plug-in only] Video Capture sometimes stop when there are scene changes
ADS Instant DVD II compatibility issue was fixed
Print to Tape problem was fixed
Problem with the background color always being black in a slide show was fixed.
In CG Infinity, the problem of the object color changing when Moving Path is applied was fixed
Problem with DV files with corrupted frames when created on a system with Hyper-Threading enabled was fixed
Occasional synchronizing problems in Preview window were fixed
DVD-NTSC template configures the video's frame type wrongly therefore causing video with Lower Field first to fail to Smart Render. This problem was fixed
Audio synchronization problem when a PAL MPEG-1 video is converted to a NTSC DVD video was fixed
Problem with the Field Order option being grayed out in some situations was fixed.
Image relink problem for Media Library was fixed
Auto-Deinterlace is now applied on the video during Create Video File, not during editing
Scan for Scenes bug was fixed
Problem with Video Capture only pre-scanning and capturing the first segment of video and ignoring the rest of the DV tape when the DV tape has duplicated timecodes was fixed
Known Issues:
Customized template settings (both in New project and Create Video File dialog boxes) of users will be archived and moved to another folder because the default template was updated. If you want to recover customized templates, follow the procedure below:
a. In < MediaStudio Pro 7 installation path > \Backup , open Data.log in Notepad
b. Check the path that is written in Data.log
c. In the Backup folder, copy both prjtmpMPEG.dat and savetemp.dat to the path specified in Data.log. This will overwrite the new files that were installed with SP2 with the customized templates
When importing a VideoStudio 8 project with SmartSound audio clips, SmartSound audio clips will be ripped. Other audio clips can be imported without problems
VST audio plug-in has to be put in a specific path to make it work. It must be placed in this path:< MediaStudio Pro root > \Ulead Systems\Ulead MediaStudio Pro 7.0\aft_plug\VST
Beitrag Beitrag 1 - Verfasst am: Fr Nov 19, 2004 9:47    Titel: Antworten mit Zitat
Hast Du die schon gefunden? ich nicht.
Das 2-pass-Encoding funktioniert allerdings prima.
Sonst habe ich noch nichts Besonderes gesehen.
Glückauf aus Essen
hannes
videowahn
Beitrag Beitrag 2 - Verfasst am: Fr Nov 19, 2004 10:13    Titel: Antworten mit Zitat
> Add new filters and effect: Pan & Zoom, Duotone and Album transition Hast Du die schon gefunden?hannes
Ich hab noch nicht danach gesucht. Hab das Ding gestern um 1 Uhr runtergeladen (wer weiß, vielleicht verschwindet es ja wieder )
schnell installiert und bei den Projecteinstellungen das 2pass-Encoding gesucht. Entgegen der (englischen) Beschreibung kann man das sehr wohl bei den Projecteinstellungen anwählen (dafür geht AC3 nimmer).
Dann hab ich noch einen Film "an-"gerendert, schien alles zu funktionieren. Und dann sind mir die Augen zugefallen , man ist halt nicht mehr der Jüngste.
Geo
Anmeldungsdatum: 16.06.2002
Beitrag Beitrag 3 - Verfasst am: Fr Nov 19, 2004 10:25    Titel: Antworten mit Zitat
VideoFilter:
Pan & Zoom = Schwenken & Zoomen
Duotone = Duotone
Übergänge:
neues Verzeichnis ALBUM
mit einem Umblätter-Effekt
Nachtrag
Hier ein paar Bilder zum Patch:
LINK
Gruß Georg
schau mal vorbei: VIDEO-Intern und Ulead-Fanboard
Beitrag Beitrag 4 - Verfasst am: Fr Nov 19, 2004 18:57    Titel: Antworten mit Zitat
Danke, Georg,
schon sehr aufschlußreich.
> neues Verzeichnis ALBUM mit einem Umblätter-Effekt
da habe ich gerade mal etwas mit gespielt.
"umblättern" im wörtlich sinne, schaffe ich nicht.
Zuklappen, aufklappen und auf das Bild zoomen, das krieg ich hin.
Die neuen Sachen habe ich allerdings auch erst bekommen,
nach dem ich die EFFBAS gelöscht hatte.
Glückauf aus Essen
hannes
noch ne Frage:
wer arbeitet mit COOL3D Studio? Habe 'ne Frage zum Blitz.
Beitrag Beitrag 5 - Verfasst am: Sa Nov 20, 2004 8:32    Titel: Antworten mit Zitat
MSP 7.2 arbeitet auch mit dem Canopus DV-Codec und mit dem HW-MPEG-Encoder der Canopus DV-Storm 2 Videoschnittkarte zusammen!
Als VFW-Aufnahmetreiber wird der DVStorm-RT Video Driver an der StormBay für Composite und S-Video in MSP7.2-VideoCapture erkannt.
videowahn
Beitrag Beitrag 6 - Verfasst am: Sa Dez 04, 2004 8:36    Titel: Antworten mit Zitat
Nur als Hinweis:
Nach Installation des Patches läuft bei mir das parallel instalierte MSP 6.5 nicht mehr.
BongoBong
Anmeldungsdatum: 22.07.2003
Beitrag Beitrag 7 - Verfasst am: Mo Dez 06, 2004 10:33    Titel: Antworten mit Zitat
Ich hab am Wochenende das SP2 installiert und bin erstmal sehr erschrocken. Gleich nach dem Start des Videoeditors ist er abgestürzt. Selbst nach deinstallieren des SP2 lief das MSP 7 nicht mehr.
Erst nach kompletter Neuinstallation des MSP 7 und installieren des Update Patch 7.01 konnte ich das SP2 installieren.
Jetzt läuft alles ohne Probleme.
Bin mal gespannt welche Qualitätsverbesserung das 2-Pass-Encoding bringt.
Dirk
