Ossi
Anmeldungsdatum: 09.07.2002 Beiträge: 291 Wohnort: München
Beitrag 0 - Verfasst am: Fr Apr 30, 2004 12:52 Titel: |
gibt ein Update für den CCE Basic mit neuen Funktionen und aktualisiertem Handbuch.
Zitat: | ------------
New features
Change
- Updated encoder engine to 2.69.
Enhancements
- Supported Adobe Premiere Pro. (plug-in version)
- Enabled to output bottom field first stream.
- Added automatic resolution conversion function.
- Added quantization characteristics setting.
- Added de-interlacing function.
- Added blanking function.
- Enabled to save/load template to/from file.
- Enabled to use the last modified parameter setting.
- Enabled to specify file size.
- Enabled to shut down the system when finished encoding.
- Enabled to play a sound file when finished encoding.
http://www.cinemacraft.com/eng/topic.html#30
Ossi
dvdmaster
Beitrag 1 - Verfasst am: Fr Apr 30, 2004 17:35 Titel: |
Na endlich auch mal bff nicht immer nur tff streams.
TV: Sanyo 82 cm
CD+DVD+VCR: HTPC+Foobar
AMP: Pioneer VSX-609
SPEAKER: Canton Movie 10mx
Phono Pre: Project Tubebox |
Beitrag 2 - Verfasst am: So Mai 02, 2004 16:23 Titel: |
Das ist etwas genauer - und aktueller:
Zitat: | -------------------------------------------------------------------------------
Cinema Craft Encoder Basic Release History
Copyright © 1998-2004 Custom Technology Corporation. All rights reserved
Version 2.69.01.04 Wednesday, March 24, 2004
Bug Fix
- Reference timecode was not saved to "Previous setting" template.
Change
- Updated User's Guide.
Version 2.69.01.03 Monday, February 23, 2004
Bug Fixes
- Memory leak occurred when AVI file without audio is loaded.
- At frame search on video trimming window, previewed frame and timecode were
jumped back to previous ones when trying to move frame by frame using arrow
keys after moved to the directly typed timecode.
Version 2.69.01.02 Tuesday, February 17, 2004
Bug Fix
- It might not be able to read an AVI file which has less than 3 frames.
Version 2.69.01.01 Wednesday, January 21, 2004
Bug Fixes
- 2.67 templates was not applied to input files correcly.
- Fixed minor bugs.
Version 2.69.01.00 Monday, January 19, 2004
Change
Enhancements
Version 2.67.01.19 Tuesday, November 18, 2003
Bug Fix
- Type-1 DV AVI files may have caused an application error just before
encoding finishes. (standalone version) |
_________________ Grüße
