kow123
Anmeldungsdatum: 24.11.2003 Beiträge: 13
Beitrag 0 - Verfasst am: Di März 23, 2004 8:56 Titel: |
eine neue 1.4 Standard-Beta 2 gibt es auf der Downloadseite. Hat schon jemand von den Profis Erfahrungen damit? |
Beitrag 1 - Verfasst am: Di März 23, 2004 10:14 Titel: |
Achtung! Es handelt es sich hierbei um die Standard-Version
22.03.2004
[b]Version 1.4 (BETA 2)[/quote] download dvdlab14b2.exe (4MB). There are no backgrounds, buttons or any templates so you need to have 1.3 full installed before adding this update.
- New multiplexer that should fix the WAV problems together with few other muxer related issues
- The File Browser is completely redone (the MS stuff is out), now with file info, color coding, favorities and ability to preview files.
- Menu Object can have various new effects - Bevel, Glass, Mirror, Magnifier...
- The Render Motion Menu some work, smoother fine scrub, Pre-Buffering (starts decoding a movie bit earlier and then extact frames when the decoder ir "warmed up". This should fix the first GOP jump issue)
- Plug-ins folder in assets, has space for Plug-ins (Components, Scripts)
- Run lab-TALK scripts in either interpreting mode or pre-compiled form (in C++ for example)
- Run Smart Components - a component with embedded script
- Fix for LPCM multiplexing issues with Panasonic and few others.
- DCT Transcoder to reduce size of asset files. This operates similarly to DVD Shrink or DVD2One, (but on the input mpeg files rather than on whole DVD) where the transcoder simply reuse mpeg motion vectors and therefore recompress the mpeg file size in just few minutes. This is just a means for a quick reducing less important files. Make sure you know the tradeof.
- Audio Delay Info. If you select Program Stream in assets and click Audio Delay button you will get the info of the PS A/V delay. If you select audio file then it is as before - correct Audio Delay.
- MPEG-1 ES files can now be previewed and compiled
- Direct access from DVD-lab assets to TMPGEnc AC3 plugin (WAV and MPA transcoding)
- New and improved demultiplexer, now it will demux in 2 pass (video then audio) which prevents from fragmentation of the disc. It is also faster and more stable than previous one.
- Component system in Connection windows - you can group objects and use them as black box, you can also export/import such components
- Adobe Photoshop 6,7 export/import fixes
- Load Sub Picture now converts the subpicture to 4 Colors
- You can directly drag images and *.mnu files from explorer to menu
- Output folder is now saved with the project.
- Testing mpa audio frequency in PS mpg without demuxing throw error if not 48kHz.
- You can also drag link from Project to Connections Menus and it will behave as if you use Draw Button Links. Bit awkward but the option is there.
- Some changes in mpa testing, the large allocated buffer seems to caused some problems
- Rebuild All Transitions on one click
- Add Transition Tool in connection (Draw arrow from menu to menu)
- Test compile now replaces also slideshow. The dummy image is now dynamically generated with information about the movie.
- Fix for the case when two or more menus with 16:9 motion background would crash compiler.
- Choose type of Default (Empty) project or create your own default project.
- Some changes in Record module - now you can manually select the type of DVD which works more reliably than auto-sensing. _________________ Gruß SVCDFan |
Beitrag 2 - Verfasst am: Di März 23, 2004 12:40 Titel: |
Hmmm ? Was soll das heißen _________________ Wenn mer sich uffreche will: - Eintrachtfan und SPD Mitglied! |
Alien
Anmeldungsdatum: 28.03.2002 Beiträge: 248
Beitrag 3 - Verfasst am: Di März 23, 2004 13:31 Titel: |
@Helmut
Na, schau mal hier. Lesen bildet . Der gute Oskar hat schon lange eine Trennung zwischen Standard- und Pro-Version angekündigt. Und nu hatter eben eine 1.4 Beta 2 der Standard-Version fertig. Die Pro muss noch ein bischen gären. _________________ Ciao, Alien
2xSeagate 60GB
LG GSA-4120B
LG GCC-4480B
Powercolor X800Pro
ADVC-55 |
MOIK
Anmeldungsdatum: 02.09.2003 Beiträge: 170
Beitrag 4 - Verfasst am: Di März 23, 2004 13:32 Titel: |
Zitat: | Achtung! Es handelt es sich hierbei um die Standard-Version
Hmmm ? Was soll das heißen |
DVD-lab wird ab der nächsten Version als:
- Standard und als
- Pro
Version vertickt. Die Pro-Version wird teurer, bietet dafür aber auch die lang gewünschten Tonspurenauswahl an.
Die Beta der Pro-Version lässt anscheinend noch ein wenig auf sich warten...
.... uppps, das Alien war schneller :D
Zuletzt bearbeitet von MOIK _________________ Athlon 1600+, 756 MB RAM, 2x 60 GB Feste Platten, ED AVEasy, Pio 106, MSP 7, VDL 03/04, Studio 8, Procoder Express, DVD-Lab, Nero 5.5 |
Beitrag 5 - Verfasst am: Di März 23, 2004 13:54 Titel: |
Aha ... na dann lassen wir mal die Banane beim Lieferanten reifen.
Beitrag 6 - Verfasst am: Mi März 24, 2004 12:06 Titel: |
Na gut - hab´s mir mal installiert, als Update über die 1.3.
Macht einen guten Endruck. Aber immer noch keine mehrere AudioSpuren. Nööö ... warten wir mal auf die ProVersion. _________________ Wenn mer sich uffreche will: - Eintrachtfan und SPD Mitglied! |
