TMPGEnc Plus DVD Author 1.5.20.62
Beitrag Beitrag 0 - Verfasst am: So Nov 02, 2003 20:26    Titel: Antworten mit Zitat
TMPGEnc Plus DVD Author 1.5.20.62 - February 5 2004
Improved
[1] Px engine (DVD writing tool) has been renewed. Thanks to this, problem related to process such as "Fast User Switching" in Windows XP should be also resolved.
[2] In environmental settings, you can choose to "re-encode LPCM or MP2 audio to Dolby Digital (AC-3) audio as default." This setting can be chosen for both NTSC and PAL.
TMPGEnc Sound Plug-in AC-3 Ver.1.06 - February 5 2004
Fixed
- Some problems concerning Internet connection (License validation) have been resolved.
TMPGEnc Plus DVD Author 1.5.19.59 - January 16 2004
Added
[1] It supports the AC-3 plug-in. You can encode/decode AC-3 sound if you have the plug-in. When the AC-3 plug-is recognized, the AC-3 logo appears in the version information:
click [Options]-[About TMPGEnc DVD Author] .
Improved
[1] The sampling rate converter has been renewed.
[2] The thumbnails display is more precise, in [Edit clip] window.
[3] The "audio desync" correction is more accurate, when adding a new clip or when authoring.
[4] The length estimation of MPEG system stream is more accurate.
[5] The DVD writing tool has been renewed.
TMPGEnc Plus DVD Author 1.5.15.49 - October17 2003
Improved
[1]The MPEG file parsing function.
[2]The quality and the speed of the "sound re-sampling".
[3] The DVD writing tool [PxEngine] has been updated.
[4] The transition to Standby, during the writing process(DVD writing tool), will be locked from the new version.
[5]The script used for ,"when the tracks has been played, display Main menu".
Fixed
[1] When reading DVD-Video/VR, the aspect-ratio information of the IFO will be used prior to the MPEG one. It will fix a problem occuring when reading some 16:9 (aspect ratio) source file as 4:3 source file.
[2] For the MPEG decoder, the bug concerning the header reading-error of MP2 and AC3 has been fixed.
simbae
Anmeldungsdatum: 04.04.2002
Beitrag Beitrag 1 - Verfasst am: Mi Jan 21, 2004 20:55    Titel: Antworten mit Zitat
Neue Version online.
Added
Improved
Wie oben zu lesen AC3-Plugin verfügbar.
OgerTian
Anmeldungsdatum: 16.02.2002
Beitrag Beitrag 2 - Verfasst am: Do Jan 22, 2004 23:17    Titel: Antworten mit Zitat
das programm ist recht streng. dvb zeug nimmt es nur wenn ich es in pva aufnehme und dann mit da.jar wandeln lassen und so späse wie 16:9 und 4:3 auf einer dvd geht nicht.. (sowas geht sogar mit maestro.)
simbae
Beitrag Beitrag 3 - Verfasst am: Do Jan 22, 2004 23:44    Titel: Antworten mit Zitat
lol
Was heißt hier SOGAR?
Der Maestro is zwar pingeling, was Auflösungen angeht (und das kann man ihm austreiben), aber sonst gibts nix zu mäkeln.
Die Verschachtelung von verschiedenen AR´s auf EINER DVD is nunmal kein Kinnerkram und wird von den meisten, nicht zuletzt von den etwas günstigeren nicht unterstützt.
Auch das vielgelobte DVDlab (im Low-Mid-Price-Bereich) konnte des bis vor kurzem net ...
EiGuscheMa
Anmeldungsdatum: 10.09.2002
Beitrag Beitrag 4 - Verfasst am: Mo Feb 02, 2004 11:19    Titel: Antworten mit Zitat
Die Pingeligkeit des TMPGencDVDAuthor bei den Auflösungen ist übrigens auch "austreibbar".
Wenn man die interne Formatprüfung austrickst, wird auch von 480x576 eine ruckelfrei und synchron laufende DVD erzeugt.
Interessant vielleicht für diejenigen, welche DVD im -VR Format (von einem Standalone) in eine DVD-V umwandeln wollen.
Beitrag Beitrag 5 - Verfasst am: Do Feb 05, 2004 11:59    Titel: Antworten mit Zitat
Improved
Fixed
A190Norbert
Anmeldungsdatum: 24.02.2003
Beitrag Beitrag 6 - Verfasst am: Di März 02, 2004 17:51    Titel: Antworten mit Zitat
Hallo Zusammen,
TMPEG hat auch mit dem Author in meiner Registry rumgerödelt. Ich will meine Reg in den Zustand vorher zurückversetzen. Welchen Eintrag nimmt TMPEG Author vor ?
Norbert
A190Norbert
Beitrag Beitrag 7 - Verfasst am: Di März 16, 2004 15:34    Titel: Antworten mit Zitat
Ich glaube ich bin hier im falschen Film.
Nochmal im Klartext. Wenn man den TMPEG Author installiert und dann startet, dann wird in der Windows Registry ein Eintrag vorgenommen. Ähnlich macht das auch der "normale TMPEG". Kennt jemand diesen Eintrag damit ich Ihn restlos aus Registry wieder herauslöschen kann?
Bitte keine kryptischen Angaben die aus der Release Info herauskopiert wurde.
This for the englisch participants:
I would like to know if there is any registry entry after first start of TMPEG Author. Please dont´t send me a copy of the update information.
Norbert
Kika
Anmeldungsdatum: 11.06.2001
Beitrag Beitrag 8 - Verfasst am: Di März 16, 2004 18:16    Titel: Antworten mit Zitat
Wir haben Deine Frage schon verstanden, soooo kompliziert ist die nicht.
Es ist nicht ein Eintrag, es sind etliche.
Und die wird hier niemand veröffentlichen, da ihre Kenntnis eben nicht nur zum Entfernen der Einträge genutzt werden kann, sondern auch zum Umgehen der 30 Tage-Beschränkung.
A190Norbert
Beitrag Beitrag 9 - Verfasst am: Do März 18, 2004 14:45    Titel: Antworten mit Zitat
Hallo Kika,
vielen Dank für den Hinweis. Natürlich wollte ich nur mein System von überflüssigem Ballast befreien aber bevor ich mir meine Reg strubbelig mache, lasse ich lieber die Finger davon.
Norbert
Beitrag Beitrag 10 - Verfasst am: Do März 18, 2004 19:14    Titel: Antworten mit Zitat
Du könntest natürlich ein TDA freies System nehmen, die Reg sichern,TDA installieren , die reg sichern und
Dir die Unterschiede anschauen.
A´ber sowas machen brave Leute nicht.
xyladecor
Anmeldungsdatum: 22.09.2001
Beitrag Beitrag 11 - Verfasst am: So Apr 25, 2004 2:18    Titel: Antworten mit Zitat
[quote=EiGuscheMa,Feb. 02 2004,10:19]Die Pingeligkeit des TMPGencDVDAuthor bei den Auflösungen ist übrigens auch "austreibbar".
Interessant vielleicht für diejenigen, welche DVD im -VR Format (von einem Standalone) in eine DVD-V umwandeln wollen.[/quote]
und wie macht man das genau?, bzw. kann man das programm so weit austricksen, dass es mpeg streams mit 544 x 576 (PAL) nimmt?, weil die herumpatcherei nervt mich mit der zeit gewaltig?
wäre klasse, wen ich mir das ersparen könnte...
ciao ciao
xyladecor
Beitrag Beitrag 12 - Verfasst am: Mo Apr 26, 2004 14:44    Titel: Antworten mit Zitat
kann mir da wirklich niemand helfen, laut diesen posting soll es ja möglich sein, und da es ja tatsächlichen einen "grau unterlegten" IGNORE button gibt kann ich mir das auch gut vorstellen, nur leider kann ich nirgends finden wie man den aktiviert.
ich denke mir, dass es ein bestimmter registry eintrag ist, nur welcher???
ciao ciao
EiGuscheMa
Beitrag Beitrag 13 - Verfasst am: Mo Apr 26, 2004 21:54    Titel: Antworten mit Zitat
Das geht leider nur mit Patchen der .exe Datei.
Und was man da patchen muss, kriegt man nur durch reverse enigineering raus.
Und da das ja bekanntlich verboten ist, darf sowas hier nicht im Board stehen.
Oder per Email oder PM versandt werden.
Schliesslich wollen wir ja noch alle miteinander alt werden.
(falls nicht bereits geschehen..... )
Beitrag Beitrag 14 - Verfasst am: Di Apr 27, 2004 11:24    Titel: Antworten mit Zitat
Was man bei einigen Programmen patchen muß steht in der Linksammlung.
Ist das böse , wenn man nur die Adressen angibt und was da reingeschrieben wird ?
Für den TDA weiß ich es leider auch nicht, da patche ich immer, wenn ich so einen Murks denn mal mache.
EiGuscheMa
Beitrag Beitrag 15 - Verfasst am: Di Apr 27, 2004 14:28    Titel: Antworten mit Zitat
BergH,
meinst Du das, was z.B. der Mapelt zu Maestro geschrieben hat?
Sowas würde ich wohl auch noch für den TDA zustandebringen...
Mal sehen, vielleicht am Wochenende...
Beitrag Beitrag 16 - Verfasst am: Di Apr 27, 2004 16:22    Titel: Antworten mit Zitat
Ich würde Dir dafür danken.
(Obwohl ich es ehrlich selten brauche).
Wenn ich SVCD auf CD habe schaue ich sie von der CD.
Alle 30-45 Minuten komme ich noch hoch.
Das in DVD wandeln ? Wozu ?
Na ja es gibt Fälle, wo ich das mache, aber selten.
Beitrag Beitrag 17 - Verfasst am: Mo Jul 19, 2004 14:31    Titel: Antworten mit Zitat
servus,
wenn ich mal son file hab,hau ichs ungeauhtort auf ne 4x dvd-rw.
mein aldi player spielts.dann wirds gelöscht.mache mr net mal die mühe sowas zu authoren,da ich es meistens sowieso net archiviere.
eiguschema:
naja,pm´s sollten doch privatssphäre bleiben..
videowahn
Beitrag Beitrag 18 - Verfasst am: Mo Aug 15, 2005 16:08    Titel: Antworten mit Zitat
Warum kostet der DVD Author als Retail in den USA nur $49
inclusive:
-TMPGEnc DVD Source Creator
-DVD Writing Tool
-Built-in Dolby Digital Audio (AC-3) encoder/decoder
Ist das der Spezialpreis für kriegsführende Nationen?
