Neue Version: 2.520.54.163
Beitrag Beitrag 0 - Verfasst am: Fr Jul 18, 2003 9:30    Titel: Antworten mit Zitat
Friday June 18th 2003
Notification of new updates for the TMPGEnc series
Dear Customer,
Thank you very much for using our products.
We are taking the liberty of informing you that we have released the
latest update for TMPGEnc Plus.
* TMPGEnc Plus English version 2.520.54.163
You can find the links for the download as well as the revision history here:
http://www.pegasys-inc.com/e_download.html
These updates corrects several problems as well as offer more features and
we encourage you to update your version.
This time, the main new feature is the MPEG decoder of CRI Sofdec!
Best regards,
Pegasys Inc.
Revision History
Added
Includes the MPEG decoder CRI Sofdec. Now, input of MPEG-2 files is a standard feature. Plus, the picture quality (brightness, color) shown on your pc display will be close to the one on your TV. So the editing will be easier.
*when using CRI sofdec:
remove the check on [ Output YUV data as Basic YCbCr not CCIR601 ]
[ Setting ] => [ Quantize matrix ] => [Output YUV data as...]
*when using CRI sofdec, you can open a maximum of 8 sequence files as a movie.
Fixed
Made minor corrections.
