thedigital
Beitrag 0 - Verfasst am: Fr Feb 08, 2002 8:50 Titel: |
MoinMoin,
ich habe ein MPG-File mit TMPGEnc 12a erstellt, 4300 Video + 112 Audio und max. VBV
Das Video stottert. Jetzt habe ich das File mit bbmpg demultiplext und neu multiplext. Diese Meldungen entstanden:
Scanning video stream for pictures ...
Found 27002 picture headers.
Video stream information
Stream length : 580545775
Total time (seconds) : 1080
Sequence start : 1811
Sequence end : 0
No. Pictures : 27002
No. Groups : 1811
No. I Frames : 1811 avg. size 58195 bytes
No. P Frames : 7208 avg. size 39863 bytes
No. B Frames : 17983 avg. size 10443 bytes
No. D Frames : 0 avg. size 0 bytes
Horizontal size : 480
Vertical size : 576
Aspect ratio : 0.6735
Picture rate : 25.000 frames/sec
Bit rate : 537500 bytes/sec (4300000 bits/sec)
Computed avg rate : 538750 bytes/sec (4310000 bits/sec)
Computed max rate : 605150 bytes/sec (4841200 bits/sec)
Vbv buffer size : 229376 bytes
CSPF : 0
Scanning audio stream for access units information
Found 41349 audio frame headers.
MPEG audio stream information
Stream length : 15121920
Syncwords : 41349
Frames : 11814 size 365 bytes
Frames : 29535 size 366 bytes
Layer : 2
CRC checksums : yes
Bit rate : 14000 bytes/sec (112 kbit/sec)
Frequency : 44.1 kHz
Mode : 0 stereo
Mode extension : 0
Copyright bit : 0 no copyright
Original/Copy : 0 copy
Emphasis : 0 none
NOTE: Mux rate may be too low for data rate, watch for PTS/DTS underflows.
Multiplexing information
Video stream data rate : 605150 bytes/sec (4841200 bits/sec)
Audio stream 1 data rate : 14000 bytes/sec (112000 bits/sec)
Total data rate : 348600 bytes/sec (2788800 bits/sec)
Multiplexing file temp.mpg
video PTS (260.00ms) underflow at pack 46 by 46.67ms
video PTS (300.00ms) underflow at pack 50 by 33.33ms
video DTS (340.00ms) underflow at pack 54 by 20.00ms
video PTS (380.00ms) underflow at pack 67 by 66.67ms
video PTS (420.00ms) underflow at pack 70 by 46.67ms
video DTS (460.00ms) underflow at pack 75 by 40.00ms
(viele weitere)........
video PTS (1080140.00ms) underflow at pack 260686 by 657766.67ms
video DTS (1080180.00ms) underflow at pack 260690 by 657753.33ms
26995 video underflows (SCR >= PTS or DTS)
NOTE: The resulting file may not play back correctly.
Try reducing the video bitrate or increasing the video and
audio startup delays.
Finished multiplexing temp.mpg
Calculating 1811 SVCD user data scan offsets for file temp.mpg
Finished calculating SVCD scan offsets for file temp.mpg
Und tschüss,
Thorsten. |
Svennek
Beitrag 1 - Verfasst am: Fr Feb 08, 2002 9:07 Titel: |
Mahlzeit,
schon versucht, die Mux-rate in bbMPEG auf null (=auto) zu stellen und falls das nicht funktioniert, VBR anzukreuzen (auch wenn es CBR ist) ?
Sven |
TV8
Anmeldungsdatum: 29.09.2001 Beiträge: 132
Beitrag 2 - Verfasst am: Fr Feb 08, 2002 9:12 Titel: |
Wenn der Ton und das Bild stottert ist die Datenrate zu hoch.
Langsam zurück gehen.
TV 8 |
thedigital
Beitrag 3 - Verfasst am: Fr Feb 08, 2002 11:27 Titel: |
Grütze! Thread löschen! Hab' nochmal Stefans http://www.edv-tipp.de/dvd/033_vbv_mux.htm gelesen. Also nix Datenrate runter. Richtige Muxrate finden.
Probiere mal die 0 (Automatic) sowohl bei bbmpeg und tmpgenc.
Und tschüss,
Thorsten former known as El Verwirro!
PS: Und nix neuer Ruckeltyp - eher neuer Dusseltyp *lol* |
Beitrag 4 - Verfasst am: Fr Feb 08, 2002 17:16 Titel: |
Nee, neee der Tip war schon richtig:
Es gibt Player die bei 4500-5000 anfangen zu stottern.
(wie zum Beispiel mein SEG2K.) Das Laufwerk kann nur / ist gebremst auf 4 fach CD-speed lesen.
Da ist dann ab dem o.a. Bereich Ruckeln angesagt, weil das Laufwerk nicht mehr mitkommt.
Es gibt Player die konnen sogar nur 2 fach sprcih die 27** vom
SVCD Standard !
Kannst ja mal testen wann Dein Player abregelt ! |
thedigital
Beitrag 5 - Verfasst am: Sa Feb 09, 2002 9:11 Titel: |
@bergH:
Die Geschwindigkeit hab ich mal getestet. Bei DVD liegt sie etwas höher als bei SVCD; liegt ja an der Packetsize. Darum war/bin ich ja so verblüfft gewesen, daß jetzt auf einmal das stottern anfängt (bei SVCD).
Der Auszug aus TMPGEnc weißt m.E. eindeutig auf den VBV. Hat Stefan ja auch schön erklärt.
Und tschüss,
Thorsten |
thedigital
Beitrag 6 - Verfasst am: Sa Feb 09, 2002 11:55 Titel: |
MoinMoin,
Zwischenstand:
Den VBV habe ich auf 0 (== Automatic) gesetzt, und einen neuen Stream erstellt.
Ulead DVD Movie Factory erzeugt wieder einen Ruckelheini,
gleiches File in WOC hinein, und go: Nix Ruckeln.
Da fällt mir ein Tipp von Helmut ein. Image in Ulead erzeugen und mit Nero brennen. War das so? Ich versuchs mal.
Bis später,
Thorsten. |
Beitrag 7 - Verfasst am: Mo Feb 11, 2002 18:17 Titel: |
Nochmal langsaaaaaam zum Mitschreiben:
Die Speed in der das Laufwerk des Players CD NICHT DVD
wiederhole NICHT DVD ausliest !
Das sind zwei verschiedene Werte die NIx, aber auch (fast) gar nix miteinander zu tun haben.
1 fach CD ist ca. 150kB/s (Kilobyte/Sekunde), oder eben ~13** kBits (Wenn das k jezt K sein muß sagt es mir.)
2 fach CD ist eben 27** = SVCD Standard.
4 fach entsprechend ~4500 - 5000
DVD 1 fach ist ein völlig anderer (höherer) Wert den ich gerade nicht draufhabe. |
thedigital
Beitrag 8 - Verfasst am: Mo Feb 11, 2002 19:19 Titel: |
@bergH:
Hä? Hilft jetzt irgendwie gar nicht! Speeds sind klar.
Nochmal: Stream mit WOC oder NERO als xSVCD funzt. Mit Ulead MediaFactory: Ruckeln! Das ist Sachstand. Somit kann ich auf meinem System MovieFactory für höhere Bitraten und SVCD knicken. miniDVD ist i.O. Aber leider muß ich xSVCD machen, weil es Leute gibt, die blöde Player haben, aber Filme wollen.
Meine Lösung: miniDVD! Freut sich auch Helmut und kann sich bestätigt fühlen, dass xSVCD irgendwie Murcks ist!
Und tschüss,
Thorsten. |
Beitrag 9 - Verfasst am: Di Feb 12, 2002 10:23 Titel: |
Zitat: |
Wir muessen dringend an unserer Kommunikation arbeiten...
Will Smith in ID4 !
O.K. hatte ich wohl was falsch verstanden.
Movie Fuctory = keine vernünftige SVCD ! |
Svennek
Beitrag 10 - Verfasst am: Di Feb 12, 2002 10:37 Titel: |
Freud'sche Fehlleistung oder absichtlicher Verschreiber? Wieauchimmer, herzlichst gelacht ;-)
Sven |
thedigital
Beitrag 11 - Verfasst am: Di Feb 12, 2002 12:16 Titel: |
MoinMoin!
Movie Fuctory .... *japsnachluft* sag's doch gleich ;-)
MovieFactory+DVD==Gut, nur leider nix DD5.1 :-(
Und tschüss,
Thorsten. |
