DVD SVCD Forum Foren-Übersicht -> Anleitungen - Erklärungen - Hilfen - Tipps
Mpeg2 schneiden
Ted66
Anmeldungsdatum: 25.10.2001
Beitrag Beitrag 0 - Verfasst am: Di Feb 25, 2003 20:01    Titel: Antworten mit Zitat
kleines einfaches Progie um mpg2 zu schneiden
und noch dazu Freeware (auf DVD2AVI aufgebaut)
Schaut es euch mal an...sehr gut geeignet um an den DVB-Streams was wegzuschneiden.
MPEG2Cut
TEd
Beitrag Beitrag 1 - Verfasst am: Fr Feb 28, 2003 18:07    Titel: Antworten mit Zitat
Neue Version =-1.15-= erhältlich !
|MPEG2Cut by Jackei/Symbiose/Dark Avenger |
|website: http://darkav.de.vu |
| email: [url=mailto:darkav@gmx.net]darkav@gmx.net[/url] |
MPEG2Cut is a fast (in terms of usage; buffering is not good) and easy MPEG2 Cutter made by
Symbiose based on Jakei's DVD2AVI.
For personal needs I added sound output by using John Edward's WAVE OUT code for the first
mpa track muliplexed in the stream. You need to get MPAlib.dll from my site to get it work.
Furthermore you probably need about 800MHz in YUV2 mode for playback.
Unfortunately Symbiose took some older DVD2AVI version and modified it, resultig in some
display bugs and slow IDCT routines. So I updated it to DVD2AVI 1.76 code.
History:
=-1.15-=
- added experimental VOB support (was possible in previous version also)
- added experimental MPEG2 VIDEO only cutting support
- added ac3 playback
- added track selectioning while playback
- cutting: made i/o buffer bigger to hopefully speed up things
- now '0' and 'insert' will also start/stop playback mode
(so I can switch between ff/fb and play without moving my hand too much...)
- some tidbits here and there
- finally released source and taking some rest now...
