Beitrag 20 - Verfasst am: Mi Jan 22, 2003 11:56 Titel: |
PowerTools = Germanische Version
Workschop = Englische Version _________________ Wenn mer sich uffreche will: - Eintrachtfan und SPD Mitglied! |
BS3095
Beitrag 21 - Verfasst am: Fr Jan 31, 2003 22:54 Titel: |
Probiere gerade die Trialversion aus, deshalb eine Frage, wo kann man denn von PAL auf NTSC umschalten, habe den Verdacht man entscheidet sich bei der Installation für ein System, das wäre natürlich ein gravierender Mangel oder ist dem nicht so ?
Erübrigt sich habs gefunden.
:p
boedeker
Anmeldungsdatum: 22.07.2002 Beiträge: 5
Beitrag 22 - Verfasst am: Fr Feb 07, 2003 19:03 Titel: |
Es soll eine neue Workshop Version herauskommen.
Siehe http://www.ulead.com/
Ulead Systems, Inc., a leading developer of video editing, image editing, and DVD authoring software, today announced that UleadR DVD Workshop , Ulead's advanced DVD authoring software, will soon support DolbyR AC-3 audio files so that viewers can enjoy the quality of Dolby Surround Sound when watching a DVD created with DVD Workshop. The software will also include DVD AutoPlay, an auto-run player, so viewers can watch a DVD without the hassle of first installing DVD playback software on their computer.
DVD Workshop users can now import 5.1 Surround Sound AC-3 audio files and create Stereo AC-3 files within DVD Workshop. This high-quality, audio file format, also known as Dolby Digital in theatres, ensures audio playback compatibility, a higher compression rate for producing small audio files, and the ability to offer Dolby 5.1 surround sound on DVD Workshop authored discs. The software also includes Ulead AutoPlay, an auto-run DVD playback software that can be burned to DVD or VideoCD discs.
DVD Workshop is one of the first DVD authoring software products in the prosumer category to provide users with professional and flexible menu authoring features at a cost-effective price. The software has won Videomaker's Best Intermediate DVD Authoring Software Product for 2002 award, LAPTOP and eMedia Magazine's Editor's Choice and Animation Magazine's Seal of Excellence award.
Availability and Price
DVD Workshop AC-3, the full version of DVD Workshop with AC-3 support, will be available for $495. For existing DVD Workshop users, the AC-3 PowerPack can be downloaded for $199. Both products will be available at the end of February via Ulead's Web site at www.ulead.com.
gruß boedeker |
rene000
Anmeldungsdatum: 24.07.2002 Beiträge: 111 Wohnort: Berlin
Beitrag 23 - Verfasst am: So Feb 16, 2003 15:56 Titel: |
PT gefällt mir wirklich gut. arbeitet zuverlässig und die menüvorschau ist einfach nur goil.
was ich mir wünsche: ich setze als menüpunkt oft eigene avi´s (erstellt mit 3dmax z.b.). da würde ich gerne den alpha-chanel im PT für dieses avi aktivieren können. das z.b. der schwarze hintergrund im avi gar nicht dargestellt wird. das sieht um längen besser aus und die info über den alpha chanel ist im avi ja schon drin.
ansonsten superproggie - alleine die animierte hintergrundfunktion ist sehr gut und funktioniert ohne probleme.
was schön wäre:
man kann ja die buttoms highlighten. schöner wäre noch, wenn bei auswahl eines buttoms eine verknüpfung auf z.b. ein anderes hintergrund-avi erfolgen könnte, oder zumindest der buttom als solches einem avi zugeordnet werden könnte.
ansonsten gibts für mich im moment nix besseres. _________________ http://www.hex666.de
http://www.weber-work.de |
JLuecking
Beitrag 24 - Verfasst am: Di Apr 08, 2003 7:26 Titel: |
hier nun mal meine Wünsche:
- Nicht nur Kapitelbild, sondern auch Titelbild einstellen können. Gleiche Möglichkeit auch für Menüs (also bei Link auf Menü statt des Menübilds ein Bild aus dem Video setzen).
- Defaults abspeichern oder merken (u. a. Video- oder Audiorate, Verzeichnisse).
- Default im Menü, z. B. Play All als Standardwiedergabe wählen.
- 16:9 für Bilder im Menü wählen können. Letterboxformat würde mir schon reichen. Also quetschen und schwarze Balken oben und unten.
- Skip in Vorschau. Dann könnte man schon die Kapitelsprünge überprüfen.
- Vor- und Rückspulen nur, wenn es auch effizient ist. Vielleicht geht es besser, wenn die i-Frames wie bei PVACut vorher schon eingescannt werden, vielleicht schon im Hintergrund.
Joachim
Zuletzt bearbeitet von JLuecking _________________ DVD und andere Links unter Radio & TV auf meiner Site Links to the WWW |
Beitrag 25 - Verfasst am: Di Apr 08, 2003 13:05 Titel: |
Hmmm - wie meinen ? Kann man doch jetzt auch schon machen. Bild in der Timeline wählen - als Hintergrundbild speichern (wird in die Liste aufgenommen) und dann im Menü verwenden. _________________ Wenn mer sich uffreche will: - Eintrachtfan und SPD Mitglied! |
JLuecking
Beitrag 26 - Verfasst am: Di Apr 08, 2003 14:28 Titel: |
Korrekt. Habe jetzt aber eine für meine Bedürfnisse optimal ausgerichtete Vorlage gemacht, unter anderem um Zeit zu sparen. Dann brauche ich nur das Kapitelbild (statt des Titelbildes, wie es eigentlich sein sollte) reinzuziehen und brauche nicht auszurichten. Bei Links auf Menüs geht es dann nicht mehr so. Dann ziehe ich das Bild (mit den kopierten Formaten) auf den Link und versuche es so zu plazieren, dass die beiden Bilder (das neue und das mit dem Menü) deckungsgleich sind, hole den Link mit dem Menübild nach vorne und lösche es.
Wenn man nicht die Formate kopieren muss und nicht ausrichtet, kann man eine Menge Zeit / Aufwand sparen. Und es ist garantiert, dass auch die Untermenüs deckungsgleich sind.
Meine Erfahrungen mit der Erstellung von Menüvorlagen in Photo Impact werde ich in einem eigenen Thread schildern.
Joachim _________________ DVD und andere Links unter Radio & TV auf meiner Site Links to the WWW |
JLuecking
Beitrag 27 - Verfasst am: Di Apr 08, 2003 18:35 Titel: |
Noch mehr Wünsche:
- Bei der Datenträgerbezeichnung ähnlich wie bei VCDEasy Kleinbuchstaben in Großbuchstaben wandeln und ebenso Leerzeichen in Unterstrich. Macht das Eingeben einfacher.
- Toleranzeinstellung für nichtkonforme Formate, welches Patchen erspart (Leider hat Classica im Premiere Paket von 352er auf 480er Auflösung gewechselt. *Grrrr*).
Beitrag 28 - Verfasst am: Di Apr 08, 2003 18:38 Titel: |
Formuliere das mal so aus das ich das in die Liste übernehmen kann. Blicke da net recht durch. _________________ Wenn mer sich uffreche will: - Eintrachtfan und SPD Mitglied! |
JLuecking
Beitrag 29 - Verfasst am: Di Apr 08, 2003 19:41 Titel: |
Nehme an, du meinst den zweiten Punkt.
Vereinfacht gesagt: Möglichkeit auch für *nicht* kompatible Datein nicht konvertieren. Denn bis zu dem Punkt Disc erstellen macht ja Power Tools alles gutmütig mit.
luke65
Anmeldungsdatum: 23.03.2003 Beiträge: 24
Beitrag 30 - Verfasst am: Fr Mai 16, 2003 12:19 Titel: |
PWT 1.3
ist schon genial
Verbesserungen hätte ich aber trotzdem
16:9 Menü ( wurde schon genannt)
eine SHUTDOWN funktion
da das Rendern von bewegten Menüs ja etwas dauert!
MfG
mckracken
Anmeldungsdatum: 17.09.2002 Beiträge: 55
Beitrag 31 - Verfasst am: So Mai 25, 2003 15:27 Titel: |
Die VERDAMMTEN Auflösungsnormen lockern.
Bei der 1.4 will ich nichts mehr mit DVD PATCHER zu tun haben. |
Gerhard
Beitrag 32 - Verfasst am: Fr Aug 15, 2003 14:31 Titel: |
Was ich brauche:
- Zweite Audiospur für Orginalton bei Homevideo (ohne Nachvertonung)
- Untertitelspur für DV-Zeitanzeige und Datum (geht mit Reel oder Scenarist super aber Zeitaufwendig)
- Mpeg-schnitt mit SMARTRENDERING _________________ Pentium 4 3,06 CPU
460 GB Festplatte
DVD+-R,+-RW,DL & RAM Brenner
uvm.
wenzi
Beitrag 33 - Verfasst am: Do Nov 13, 2003 14:30 Titel: |
Was ich vermisse: Produktpflege !!!!!
Etwas lieblos auf den Markt geworfen, relativ viel Geld dafür verlangt... und dann sang und klanglos verabschiedet. Die Ulead-Updateseite ist gähnend langweilig. Praktisch seit über 8 Monaten keinerlei Neuigkeiten mehr. Und dafür haben wir 250 Euro gelöhnt. Dabei gäbe es durchaus noch viel zu verbessern...  _________________ Viele Grüße, Wenzi |
Beitrag 34 - Verfasst am: Do Nov 13, 2003 14:45 Titel: |
Sehe ich ned so. Das alles was jetzt in der angekündigten Version 2.0 kommen soll ist eben mehr als ein vorh. Programm zu "verbessern". Das ist halt einfach ein neues Programm - die Fülle der Neuerungen begründet das wohl zwingend.
Direkte Fehler sind ja m.E. in der Version 1.3 ned zu finden - jedenfalls keine welche die Funktionaliät einschränken würden.
Kann ja auch ned wenn ich eín Auto gekauft hab - egal wie teuer - nach zwei Jahren kommen und verlagen das die heute üblichen technischen Neuerungen "nachgerüstet" werden ..  _________________ Wenn mer sich uffreche will: - Eintrachtfan und SPD Mitglied! |
Gerhard
Beitrag 35 - Verfasst am: Sa Dez 13, 2003 12:08 Titel: |
Habt ihr das schon gehört oder gesehen?
Alles was man braucht !!!
DVD Workshop 2 _________________ Pentium 4 3,06 CPU
460 GB Festplatte
uvm.
Beitrag 36 - Verfasst am: Sa Dez 13, 2003 14:27 Titel: |
Haben wir schon in anderen Thread ausführlich bequatscht.
Schau mer mal .. hört sich ja gut an.  _________________ Wenn mer sich uffreche will: - Eintrachtfan und SPD Mitglied! |
